Flash M3 E46 SMG-ja na CSL software
66 odgovorov v temi
SONiK
SONiK
  • Sporočil: 4 574
  • Lokacija: 07
  • Avtomobil: ///M
http://http://forum....0&postcount=788
Torej sem spraševal po flashu SMG2 menjalnika na CSL software in je uporabnik @Veljo podal zanimiv link:
Tale je spisal še podrobna navodila, če se boš sam spuščal v to:
http://www.bmw-sport...to-CSL-software
Flashing SMG gearbox to CSL software
Credit to DoZZa @ M3 Cutters for this information:
So today I flashed the SMG module with the CSL SMG flash file.
Whole procedure took about 25 mins to complete and the results are very noticeable.
I used a CTEK MXS 10 to keep the battery voltage above 12v for the flash to be completed without draining the battery. I kept an eye on the voltage throughout the flash sequence using a DMM.
Cleared all codes with INPA and went for a drive.
The car now shifts much smoother, but at the same time faster. And the rev matching is vastly improved.
Highly recommend this little upgrade for E46 SMG owners.
I am more than happy to do this for members on here, but I am based in North Devon so I doubt I will get any takers. I can also do all other coding.
Attached is a link to download the PDF file with the instructions. It was not written by myself although I have edited it to include a step that was missing from the instructions that was required for me to do the flash correctly.
Follow the instructions very carefully as a wrong step could render your SMG module useless
Uporabnik @Izy pa že ima izkušnje in je napisal:
LP!!! :blabla
To misliš CSL verzijo na SMG modulu?
To ti lahko vsak naredi, ki ima obd kabl. Oziroma sam si lahko! :ok
Imam naloženo nekje pol leta. Neke bistvene razlike ne opazim več edino, da vedno spelje v A3.
Največja razlika je pri mojem ob speljevanju z mesta in avtomatski način je malo bolši.
Prej ga nisem nikoli uporabljal, sedaj ga ponavadi pustim da se motor segreje, oziroma dokler ima smisla. Po mestu je že nerodno, ker v četrto prestavi nekje pri 55 km/h. V tretji hladnega tudi nebi v nedogled držal na slabih 2500 obratih po nepotrebnem. Moje mnenje je, da se splača naložit. Še bolje se bo stvar obnesla, če se v motornem računalniku zamenja mapo za menjalnik s CSL-ovo. To je pa že malo bol podvig.
To imam v planu naštudirat do spomladi. :metalc
Odprite nekje temo in bomo tam več o tem, da nebomo smetili med oglasi. :beer
Bi kdo kaj več o tem?
Urejal SONiK, 17.01.2014, 17:32.
SONiK
SONiK
  • Sporočil: 4 574
  • Lokacija: 07
  • Avtomobil: ///M
Navodila:
http://www.docdroid....-guide.pdf.html
M3_Freak
M3_Freak
  • Sporočil: 2 262
  • Lokacija: Mb-okolica
  • Avtomobil: BMW E46 M3
Jaz sem takoj za da se to naredi. Čeprav mi zadeva deluje že zdaj ODLIČNO!!
Če kdo to zna se priporočam.
M3_Freak
:mznak Carbon Metallic Schwarz :cool
Izy
Izy
  • Sporočil: 136
  • Lokacija: Sl. Konjice
  • Avtomobil: Focus RS Nitrous Blue
Prilepim kak link, ko pridem do compa.
Prej nisem napisal do konca. Splača se to naložit, ampak samo če si lahko sam, ali max kakemu frendu dat kakega sixpack-a. Razlika je res minimalna!
    • SONiK je všeč
Izy
Izy
  • Sporočil: 136
Na tem linku si lahko pogledate še ostale možnosti. :ok2
http://www.m3forum.n...splay.php?f=109
Izy
Izy
  • Sporočil: 136
Tukaj je še nikaj linkov na temo CSL SMG software.
http://www.m3forum.n...ad.php?t=377715
http://forums.m3cutt...ead.php?t=85714
http://forums.m3cutt...ead.php?t=85546
Izy
Izy
  • Sporočil: 136
:okNaslednja stopnja! CSL SMG Engine Parameters (DME) :ok
http://www.m3forum.n...ad.php?t=457302
Kratek video iz te teme:
perobmw
perobmw
  • Sporočil: 8 654
  • Lokacija: SnoopyLand
  • Avtomobil: --------:)
M3_Freak
Ti ne rabis tega,:laugh
SONiK
SONiK
  • Sporočil: 4 574
  • Lokacija: 07
  • Avtomobil: ///M
Hoho, tole pa je... :ok :eek
Give more! :-D
SONiK
SONiK
  • Sporočil: 4 574
  • Lokacija: 07
  • Avtomobil: ///M
Tole je 10x bolš kokr stock, vsaj po videu sodeč.. :ok
ThinkPad
ThinkPad
  • Sporočil: 267
  • Avtomobil: Bimmer
Če kdo želi mu lahko flasham SMG al pa DME :ok
Izy
Izy
  • Sporočil: 136
Tole je od Evolve Automotive:
http://forums.m3cutt...ead.php?t=74899
Še video:
http://www.youtube.c...xO6KqZ_KI0#t=44
Pomoje enak učinek kot v temi : CSL SMG Engine Parameters (DME)
Izy
Izy
  • Sporočil: 136
Še ena tema od M3cutters:
http://forums.m3cutt...ead.php?t=76711
Še video:
I would have a listen to mine on the road at ~ 18 and 35 seconds...
Those 'blips' are without any throttle and if your cars sound like this already then you must have an upgrade of some kind.
The revs are matched really well so there is no 'lurching' when you change down. And on track the blips at higher revs are epic!
Tukaj se lepo sliši sihroniziranje ko prestavi v nižjo prestavo.
Izy
Izy
  • Sporočil: 136
Tukaj so zbrane ostale opcije ki se jih lahko spreminja s pomočjo NCS Expert-a:
http://www.m3forum.n...ad.php?t=372299
Pomoje zelo uporabna, ker je DSC preveč zaščitniški. M-track DSC Mode:
http://www.m3forum.n...ad.php?t=371119
Video:
Pri mojem sicer deluje kontrolka z okroglo puščico in malim s na sredini.
Tukaj je video kako preveriš če imaš aktivno M-track kontrolko:
Sicer ni M, pač prvi cluster test iz youtuba, da si lahko vsak sam pogleda, če ima lučko al ne. Sicer ni pomembno ker deluje v obeh primerih. Prikaz je edino drugačen.
Pogoj za to je, da ima avto vgrajeno MK60 DSC enoto. Moj je izdelan konec 2002 in ima. :metalc
Na DSC tipki imam sedaj tri možnosti. Ob zagonu je kot prej normalno aktiven DSC.
Na klik se vklopi M-mode, ki še vedno pazi, da ne pristaneš v jarku, dopušča pa malo spodnašanja zadka brez vmešavanja. Meni je bilo najbol nadležno speljevanje iz stranskih cest sploh spomladi, ko je še nekaj peska na robu in se je treba hitro vklučit v promet. Tudi mokre ceste in gladek asfalt je enako. Eno kolo je malenkost zdrsnilo in ostaneš sred ceste za par sekund brez gasa, ups. :damn
M-track pusti spodrsavanje koles, vsaj dokler avto drži smer.
Škoda edino, da se ZAENKRAT še ne da skodirat, da bi že takoj ob zagonu bil aktiven M-mode.
Izy
Izy
  • Sporočil: 136
Pomoje še ena uporabna tema za kako idejo, če je komu dolgčas. :laugh
The FREE or VERY CHEAP mod thread
http://www.m3forum.n...ad.php?t=179858
Če ima kdo kakšno vprašanje, lahko morda izbrskam odgovor. Žav je tako, da veliko več časa porabim za compom, kot za volanom M-a. :jok
Sicer mi je to bilo jasno že pred nakupom. Bol kot zmoglivosti me pritegne tehnika oziroma mehanika. Več kot vem o njem bol mi je všeč. In tudi več se vozim z drugim avtom. :crazy
Izy
Izy
  • Sporočil: 136
Še ena na trmo mehanike! :ok2
Nekako velja, da potrebuje vanos v naših motorjih nekaj več pozornosti.
http://forums.m3cutt...d.php?p=1199612
SONiK
SONiK
  • Sporočil: 4 574
  • Lokacija: 07
  • Avtomobil: ///M
Resno?
No v tej Smeri sem tudi Sam razmisljal in je to skoraj nujno naredit, ce druzga ne, vsaj zamenjat vijake..
ThinkPad
ThinkPad
  • Sporočil: 267
  • Avtomobil: Bimmer
Resno?
Ja resno :)
Jur3
Jur3
  • Sporočil: 2 969
  • Lokacija: Ljubljana - Sever
  • Avtomobil: Mercator vozicek
cim mn drkat po mehanskih zadevah, sploh SMGja pa bo zadeva se dolg delala
Scared Money Makes No Money
SONiK
SONiK
  • Sporočil: 4 574
  • Lokacija: 07
  • Avtomobil: ///M
:confused Sej če naložim drug program, to ni "drkanje" po mehanskih zadevah? To bi moral fizično posečt v to potem..tega se ne gremo :)
