Električni in hibridni avtomobili
* * * * - 10 glasov
10556 odgovorov v temi
Rottie
Rottie
  • Sporočil: 70 000
  • Avtomobil: E46 325i
iKst ... evo, tole je "revolucija", ne pa Tesla :ok2 Impozanten, nafilaš ga isto hitro kot navaden avto, performance tudi ima. :-D
http://jalopnik.com/...n-eu-1635321784
It's got a motor at each wheel, gullwing doors, makes a Fisker look like an AMC Pacer, and can go from stationary to 60 MPH as fast as a GT-R. It's powered by something similar to a fuel cell that uses salt water as an electrolyte. And now it's legal to drive on European roads.
The Quant is, essentially, a very high-spec electric car. It's using a motor per wheel to give it AWD with torque vectoring, and each of those motors makes 227 HP, giving a theoretical total of 908 HP. The Quant's electronics don't want you dead that easily, so the system caps the operating power at a very healthy 644 HP
The energy density of the battery is enough that the Quant is claimed to have a range of 200-300 miles or so. And, perhaps even better than range, unlike traditional chemical batteries, to recharge the battery, you only need to replenish the electrolyte, which, in this case, is just salt water. The size of the electrolyte tanks affects the overall range, and refilling them should be a quick and easy process akin to fueling up a conventional gasoline car.
Urejal Rottie, 17.09.2014, 21:35.
  • Sporočil: 24 265
Ni švoh ... ampak interior kabine je pa tak kot, da je narejen za hudo sprte zakonce ... :laugh
ponco
ponco
  • Sporočil: 1 611
  • Avtomobil: MB W212
Bodo vsaj otroci imeli tobogan v avtu :)
lp, ponco
gade
gade
  • Sporočil: 1 295
  • Avtomobil: Toyota
iKst ... evo, tole je "revolucija", ne pa Tesla :ok2 Impozanten, nafilaš ga isto hitro kot navaden avto, performance tudfd82gob00iyt7ngr3d2.jpg
dve besedi: prototip ... 1,2 mio +
Rottie
Rottie
  • Sporočil: 70 000
Res, ampak to je tisto, kar se pričakuje od resnega električnega avta (mislim na gorivo, ne same performance).
hlodek
hlodek
  • V potrjevanju
  • Sporočil: 56
  • Lokacija: .
Ljudje prosim ne delat promocije nategunom. Dajte mal prebrat o kakšni tehnologiji govorijo tile QUANT promotorji preden jim karkoli verjamete in še posebej preden linkate to drugam.
Kdor še vedno verjame pa srečno in zdrav naj ostane.
  • Sporočil: 62 373
Ja, tule mal članki zavajajo. Ni to da gre avto na vodo, ampak imajo baterije notri slano vodo. Vsaj tako je nekdo to razložil.
iKst
iKst
  • Sporočil: 8 056
Od resnega avtomobila se v prvi vrsti pričakuje kaj več kot 3D render in par PR člankov :)
  • Sporočil: 62 373
Ne vem če je to samo render, res pa da pri današnji moči 3D modeliranja ni dvakrat za rečt da ni. Je pa itak način pogona ki ga omenjajo v člankih BS.
iKst
iKst
  • Sporočil: 8 056
Bom drugač napisal. Kje se ga da kupiti, pa za kolk? Danes, ne čez 5 do 10 let.
Rottie
Rottie
  • Sporočil: 70 000
Avto obstaja in se ga lahko vidi v videu s sejma. Pa dobili so tudi že TUV, da ga lahko testirajo na cesti.
Now the company has an actual registration plate from the German TÜV Süd in Munich, which means they can start testing on public roads in Europe. There's a video of the actual, physical car here
andrej777
andrej777
  • Sporočil: 8 581
  • Lokacija: Telče (Sevnica)
Po napisanem naj bi avto delal elektriko iz slane vode? :eek
Po moji logiki težko ali pa rabis po par dolivanjih zamenjati/doliti tudi drugo komponento s katero slana voda reagira.
:ok BMW F800S AC SCHNITZER:ok
  • Sporočil: 62 373
Ne, slana voda naj bi bila elektrolit, ali sem pa jaz narobe prebral.
  • Sporočil: 62 373
http://www.avto-maga...nskim-hibridom/
Upam da je sprednji grill nastavljiv in se avtomatsko zapre. That would be cool.
andrej777
andrej777
  • Sporočil: 8 581
Ja ampak če menjaš elektrolit je treba slej kot prej tudi elektrode.
Rottie
Rottie
  • Sporočil: 70 000
Verjetno je zamišljeno, da to delaš vsake tolk, vodo pa dolivaš redno ... vprašanje je le, kolk bo to stalo, kako pogosto bo to treba delat in kako zahteven poseg bo to.
andrej777
andrej777
  • Sporočil: 8 581
Za kaj takega se sigurno rabi kakšne eksotične materiale ker če bi bilo lahko bi to delali vsi. Bomo videli kaj bo prinesel čas.
Rottie
Rottie
  • Sporočil: 70 000
Rimac Concept One Kicks-Off Formula E Campaign as Race Director
http://www.gtspirit....-race-director/
Urejal Rottie, 19.09.2014, 07:30.
  • Sporočil: 62 373
Dobro zgledata, oba. Kolk ma pa Rimac velika platišča? Ker i8 ima 19ke (če se ne motim), pa izgledajo majhne napram Rimacu.
Rottie
Rottie
  • Sporočil: 70 000
18 best and worst plug-in electric and hybrids
https://autos.yahoo....-003355826.html
