Potrebujem pomoč elektronikov(vse v zvezi z elektriko,moduli...)
27 odgovorov v temi
  • Sporočil: 21 346
Kitajec ni dal nič zraven :skrbast
Sem pa na podlagi izraza jumper našel tole: New-DC-12V-4-50W-TDA7850-Car-Audio-Power
  • Sporočil: 21 346
In to sem našel:
The lower left corner for the ACC selection Jumper: Plug-hop cap, non-ACC mode, turn on 12v power to work; unplug the jumper cap, after the ACC mode, turned on 12v power supply, but also to STBY (ie ACC ) a high level 5V-12v power amplifier to work.
Kaj sploh je razlika na koncu?
In to: If as a home (when there is no common ground) can jump to the bottom right corner of the cap shorted.
Kitajci pa njihovi prevodi :skrbast
  • Sporočil: 21 029
Primerjaj če je to enako povezano ...
  • Sporočil: 21 346
Če naj to v živo gledam, se ne vidi ravno...
Drugače pa itak ne znam :skrbast
  • Sporočil: 21 029
Iz takih fotk se ne da sledit povezav, če nimaš vezja v rokah. V priponki imaš še tovarniško dokumentacijo glavnega čipa.
Drugače pa nesi na kakšen RTV servis pa ti bodo poiskali ...
Pripete datoteke
Urejal Iztok Z., 21.09.2019, 16:11.
  • Sporočil: 21 346
Če pin nima vidne niti do njega iz nobene strani, a lahko še kako drugače najdeš povezavo, ko držiš vezje v rokah?
Tole dokumentacijo sem že našel, pa mi ni nič povedala :blackeye edino, če bi si moral kaj razlagat iz točk 4.3 in 4.4 (standby and muting in DC offset detector).
Standby and Muting facilities are both CMOS compatible. In absence of true CMOS ports or microprocessors, a direct connection to Vs of these two pins is admissible but a 470k equivalent resistance should be present between the power supply and the muting and ST-BY pins. R-C cells have always to be used in order to smooth down the transitions for preventing any audible transient noises. About the standby, the time constant to be assigned in order to obtain a virtually pop-free transition has to be slower than 2.5 V/ms.
The TDA7850 integrates a DC offset detector to avoid that an anomalous DC offset on the inputs of the amplifier may be multiplied by the gain and result in a dangerous large offset on the outputs which may lead to speakers damage for overheating. The feature is enabled by the MUTE pin (according to table 3) and works with the amplifier unmuted and with no signal on the inputs. The DC offset detection is signaled out on the HSD pin. To ensure the correct functionality of the Offset Detector it is necessary to connect a pulldown 10 kW resistor between HSD and ground.
  • Sporočil: 21 029
Iz obstoječih načrtov preverjaš povezave/prevodnost z ohmmetrom. Lahko pa za test zvežeš kar je jasno in priklopiš, potem pa preizkušaš kakšen vpliv na delovanje imajo jumperji ...
  • Sporočil: 21 346
V najslabšem primeru bom res kar po delovanju testiral :ok
Hvala za sodelovanje :ok
