Blockchain tehnologija in kriptovalute (Bitcoin, Ethereum...)
* * * * - 26 glasov
8444 odgovorov v temi
Mishko
Mishko
  • Sporočil: 3 276
  • Avtomobil: E39
Morda bi se lahko debata iz določenih tem preselila sem, kar se tiče kriptovalut in podobno.
Spodaj, za začetek, en zanimiv opis ETH (Ethereum). https://www.ethereum.org/
Possibly the most interesting use of blockchain technology in the world right now is Ethereum.
It’s incredible…but also a little hard to describe in under a million words (however I will try).
Ethereum does have it’s own currency, Ether, and like bitcoin it uses blockchain technology to record and verify all transactions, but that’s where the similarities end.
Essentially Ethereum is the world’s first decentralised computer, it uses the internet and a blockchain to keep everything synced and unhackable. Well, mostly..
Ethereum is so sophisticated that even its creators still sometimes struggle to define it and figure out what it can be used for.
Because it’s essentially a computer anyone can write code on the network that Ethereum will then execute automatically to do things such as create websites, store and execute a will, finance a company with crowdfunding, sell goods or services, and so much more.
For example, a record company could create a contract on Ethereum that automatically pays music artists every single time their records are played anywhere in the world.
If Bitcoin is a calculator, then Ethereum is a smartphone, and we haven’t even dreamed of all the possibilities yet.
- Chris Rawlinson
Urejal Mishko, 17.05.2017, 11:54.
I didn't fight my way to the top of the food chain to be a vegetarian.
Vegetarian - that's an old Indian word meaning lousy hunter.
Mishko
Mishko
  • Sporočil: 3 276
  • Avtomobil: E39
Which is better, to invest in bitcoin or ethereum and litecoins? - Ken Liu, Crypto-economist
It depends on your investment objectives and risk tolerance. If you are looking to just buy and hold one cryptocurrency, it should be Ethereum. I must warn you than holding Ethereum is not for the faint of heart. If you are the type to panic sell when you see your investments down 20–50% then it’s not for you. If you are going to quickly take profits, then it is also probably not for you. If you are looking to invest long-term and hold for at least a couple years then Ethereum could be one of the best investments you ever make.
If you are more risk averse you can go with Bitcoin or some combination of Bitcoin and Ethereum. Bitcoin is significantly less volatile but has less upside potential.
I would avoid Litecoin as a long-term investment. It has skyrocketed lately due to the recent implementation of Segregated Witness, but once Bitcoin solves it’s scaling issues there would be little reason to for anyone to use Litecoin. The network effect of cryptocurrency is very strong, and Litecoin is almost identical to Bitcoin but has far few users.
Mishko
Mishko
  • Sporočil: 3 276
  • Avtomobil: E39
Will ethereum rise to over $1500 in 5 years? - Ken Liu, Crypto-economist
The mainstream public is just starting to become aware of Ethereum, but Ethereum already has the backing of major global corporations. The recently formed Enterprise Ethereum Alliance consists of giants such as Intel, J.P. Morgan, and Microsoft.
There are hundreds, possibly thousands of Ethereum projects in development. Many of these applications are focused on making Ethereum more accessible to the general public. The world wide web was extremely inaccessible in the early days until Netscape came along and made it much easier for the general public to browse the internet. As the experience of browsing the web became much more accessible, usage exploded. Ethereum hasn’t had its “Netscape” yet, but it is in development. As these projects come online over the next few years, millions of people will be introduced to Ethereum. As the number of users continue to grow, the utility and value of Ethereum will grow exponentially.
There will likely be some growing pains along the way, but Ethereum has a great development team. Ethereum’s founder, Vitalik Buterin is very well-respected and most people in the Ethereum community believe in his vision. Having a strong leader at this stage in development is extremely important because protocol upgrades can be much more easily implemented. Since Ethereum is a relatively new cryptocurrency, its developers have had the opportunity to learn from mistakes that Bitcoin and other earlier cryptocurrencies have made and have plans to preemptively solve them.
Here are some of the upgrades that are currently in development:
Scalability improvements - Raiden Network makes 1,000,000+ transfers per second possible. Ethereum can currently handle about 15 transactions per second, while Bitcoin is limited to around 7.
Anonymous transactions - Zk-SNARKs will dramatically improve privacy by enabling completely anonymous transactions.
The transition from proof-of-work to proof-of-stake will prevent miner centralization, protect against 51% attacks, and decrease the inflation rate.
With a protocol that is continuously evolving, myriad applications in development, and an exploding user base, Ethereum to $1500 looks well within reach!
filipo
filipo
  • Sporočil: 2 430
  • Lokacija: GO
  • Avtomobil: F31
zdaj je ETH bolj švoh... denar se množično preliva v XRP in DGB
  • Sporočil: 18 703
Eth je cist kul, sploh glede na rast do sedaj. Nic ni padel kar je odlicno. Xrp je sel gor 10x v enem mesecu sam se bo tud ustavilo....
lukad
lukad
  • Sporočil: 632
  • Lokacija: *
  • Avtomobil: cayenne
DGB ? 0 potenciala, malo pumpo delajo, na veliko brezveznih kovancih to delajo, potenciala ta kovanec nima. Ripple je čudo, tukaj velja,da je v kriptu vse mogoče. Prva stvar je, da Ripple ni nič posebnega, do pumpe, ki se je zgodila pred 3 tedni je imel 24h volume med 700.000 in 2.000.000 $, Ripple kot valuta ni nujno uporaben kot plačilno sredstvo na platformi, developerji imajo cca 50% vseh Ripplov... tko zelo shady zadeva in kar nevarna za kripto, ker če dumpnejo developerji zna slabo vplivati na ves kripto svet.
ETH pa se je stabiliziral na 88 - 90$, nekako kot sem predvideval. Do julija kakšnih večjih skokov ni za pričakovati, razen, če se bo začel velik dump brezveznih zgodb kot so litecoin, bytecoin, ripple in podobnih. Takrat se zna ogromno kapitala preliti v btc in eth.
lukad
lukad
  • Sporočil: 632
  • Lokacija: *
Zanimivi projekti po mojem mnenju so
#1 eth potem dolgo nic potem pa gnosis, augur, golem, round pa maid, ceprav se maid ze malo predolgo vlece brez pravega napredka, ce rata bo pa bolnica.
Prihaja pa par hudih projektov, ampak je cap pri zbiranju sredstev , tako, da moram biti tiho, ker drugace sam sebi konkurenco delam :)
Ce bo slucajno brez omejitve (malo verjetno) vas pa obvestim vsekakor.
stonesour
stonesour
  • Sporočil: 1 081
  • Lokacija: Povsod
  • Avtomobil: avto
Pobje a se splača kupt Litecoine? Cena je ugodna...
  • Sporočil: 18 703
Ko bodo prazni kovanci zaceli crkovat bodo trejderji sigurno brzali v btc in eth. Jest nisem tako ambiciozen, da bi vmes tredal.
Samo cicam pa cakam :-)
  • Sporočil: 18 703
Bistvo tega pa je, da se ne zanašaš na te coine. Če rata je super, če pa ne pa še vedno delaš kar si delal do sedaj in živiš normalno življenje naprej. MOraš bit dost zrel za to, da si ne uničiš lajfa. Ker to je lahko kot droga, tako kot vsaka druga.
filipo
filipo
  • Sporočil: 2 430
  • Lokacija: GO
  • Avtomobil: F31
ripple je sprožil ripple efekt... par odmevnih novic, pojav na novih borzah, posledično rast in velik priliv novih vlagateljev... pol pa še novica o omejitvi oz. lock-upu števila kovancev in nazadnje izjava JP Morgana da je xrp best coin... pomojem xrp filajo ravno banke, ker je coin nad katerim lahko upravljajo... upoštevat je treba da je zdaj velik priliv novih vlagateljev, kjer je catch the cash pred tehnologijo... :)
v glavnem če točno ta trenutek kupiš XRP in ga čez točno 5ur prodaš lahko narediš kar nekaj profita... :)
  • Sporočil: 21 554
Lumen je tudi šel lepo gor zadnje dni, zdaj se je malo umiril.
filipo
filipo
  • Sporočil: 2 430
  • Lokacija: GO
  • Avtomobil: F31
xrp kot predvideno že nori... lumen ni več takega hypa... litecoin je segwit hype totalno zje.... vprašanje kdaj pride k sebi
Kobal trans
Kobal trans
  • Sporočil: 2 234
  • Lokacija: Mb
  • Avtomobil: kombi
Ripple je vseeno še vedno med najcenejšimi kovance, tudi če ošteješ vse ostale faktore je že iz vidika cene zanimiv.
M Kompakt
M Kompakt
  • Sporočil: 9 972
  • Avtomobil: Ruzak
In poznavalci, ste že bogati? Se vozijo M-i, AMG-ji, gradite hiše?
Jaz ne verjamem v nič virtualnega. Sem tipični balkanec, dokler ne pošlatam, za mene ne obstaja :-D
Enako je z veliko wannabe milijarderji. Vse v delnicah in obveznicah in ostalih pizdarijah. Čez noč, pa lahko ostane brez vsega. Kje je denar, zlato...to je vrednost!
Urejal M Kompakt, 18.05.2017, 06:53.
    • Rottie je všeč
Plavi
Plavi
  • Sporočil: 6 308
  • Lokacija: .
  • Avtomobil: F10
Sej v virtualo daš toliko, kolikor lahko pogrešaš brez skrbi. Če rata super, če ne pač ne. To je enako, kot če greš v Casino, Vzameš toliko za kolikor se ne sekiraš in niti centa več.
_peters_
_peters_
  • Sporočil: 5 033
  • Lokacija: Svet
To tudi mene zanima ...
So bile velike napovedi o upokojevanju ... Bentlijih ne vem kaj se vse ... Ampak kakor kaze se vedno tolcejo isto revscino ... Sem reku, brezveze.
Urejal _peters_, 18.05.2017, 07:28.
  • Sporočil: 18 703
Zlato je zelo rizicna nalozba, komot izgubis 30% v enem letu. Kdor je in bo veliko zasluzil s katerim koli poslom sigurno ne bo tega napisal na forum....
Je pa danes eht spet zacel lepo rast, smo ze na 84 :-)
A denar na banki lahko poslatas? Tko so mislili tisti ki so ga meli na banki pa veliko popusili zarad tega. Vse danes je virtualno razen kuhane klobase, ki jo mas na krozniku, pa se ta cez 5 minut izgine....
    • mico in Mishko uporabnikom je všeč to sporočilo
M Kompakt
M Kompakt
  • Sporočil: 9 972
  • Avtomobil: Ruzak
Kdo pa se ima denar na banki? S kartico si lahko kupim kruh v merkatorju, kaj pa z virtuozo?
  • Sporočil: 18 703
Najboljs je met denar pod povstrom. Eur tudi vsak teden spreminja vrednost. Vcasih sem za 1 eur natocil 1.5litra dizla, danes pa samo se 7 deci. Se pravi je eur izgubil 50% vrednosti v tem casu....
