M3 E46 olje
9 odgovorov v temi
klemenck
klemenck
  • Sporočil: 74
  • Lokacija: Zmajev brlog
  • Avtomobil: A4,M3
Kašno olje se daje v ta vozila? Sem mal prebiral teme in zdej ne vem kaj je s tem Castrolom, ker prej je bil tws, zdej pa edge in edge supercar... Pa objave so že stare... Al treba kakšno drugo znamko?
Hvala za odgovore!
Klemen
m4tj4z
m4tj4z
  • Sporočil: 4 175
  • Lokacija: zasavje
  • Avtomobil: bel traktore
Najbolj če se obrneš na...
https://www.bmwslo.c...dostava/page-93
A si kupil uno iz Kopra?
neJEZImo Save
coffa06
coffa06
  • Sporočil: 1 905
  • Lokacija: PREVALJE
  • Avtomobil: F82 ACS
Bivši TWS je sedaj edge 10w60. Tega jaz uporabljam in verjetno večina lastnikov.
  • Sporočil: 2 885
A ni sedaj supercar?
TIN
TIN
  • Sporočil: 4 417
  • Lokacija: CELJE
Uporabi liqimoly 10-60 vijolicna embalaza...dalec najboljse olje,ne pa neki kvazi kikiriki castrol.
Nimesis
Nimesis
  • Sporočil: 1 255
  • Lokacija: Blizu Lj. obvoznice
http://www.bmwblog.c...d-oil-supplier/
Product Details
BMW recommends using this specific Shell 10W60 oil in the newer M cars, including 2001-2006 E46 M3 (S54 engine), 2005+ E60 M5 (S85 engine), E9X M3 (S65 engine) and some 2000-2003 E39 M5 and Z8 cars (for S62 engine, check your engine bay prior to ordering). This oil is also suitable for the ZF transmission in the C4 Corvette ZR-1 (takes 3 liters). Priced per liter.
In January 2015 BMW changed official oil suppliers from Castrol to Shell. The new oils are designed to meet requirements of both the newer engines as well as older BMW's. This oil replaces BMW Part #: 07510009420 / 07-51-0-009-420 BMW Castrol TWS Oil. While this oil is officially labeled "M TwinPower Turbo" oil it is designed for use on the naturally aspirated S54, S65, S65, and S85 engines.
This item fits the following BMWs:
2001-2006 E46 BMW M3 coupe
2008-2011 E90 BMW M3 sedan
2008-2011 E92 BMW M3 coupe
2008-2011 E93 BMW M3 convertible
2000-2003 E39 BMW M5 sedan
2006-2010 E60 BMW M5 sedan
2006-2010 E63 BMW M6 coupe & convertible
2000-2003 E52 BMW Z8 Roadster
Rapid eye movement...
klemenck
klemenck
  • Sporočil: 74
  • Avtomobil: A4,M3
Če misliš zlato nisem.
Ne morem se odločit kaj bi dal, kaku grem sam sebi na živce kadar ne vemkaj bi... :fight
Hvala za pomoč, sej mislim da ni kej falit, če izberem med temi.
Kongo
Kongo
  • Sporočil: 363
Liqui Moly Synthoil Race Tech GT1 10W-60.
:mznak
    • TIN in 4banger uporabnikom je všeč to sporočilo
  • Sporočil: 68 360
Hvala za odgovore!
Klemen
Castrol bo OK, saj je olje te znamke gradacije 10W-60 nekaj čisto drugega kot tista njihova župa, ki nosi oznako 5W-40. V bavarce z oznako M se je vedno točil Castrol in se je vedno odlično obnesel. Če so to olje uporabljali tudi za dirkalce na pistah, kjer so toplotne obremenitve konkretno višje, bo brez problema zdržal normalno cestno uporabo. Sicer pa če je kdo v dvomih naj vpraša Blaža Podlesnika, on servisira daleč največ M modelov in bo točno vedel, kaj se najbolj obnese.
4banger
4banger
  • Sporočil: 1 427
  • Avtomobil: E46 M3&316i,koral 45
mislim da je par lastnikov e46 m3 na forumu ki uporabljamo liqui moly 10w60, jaz osebno sem prezadovoljen, tudi poraba olja in temperatura sta padli, o castrolu pa raje ne bi zgubljal besed. bmw priporoca tistega proizvajalca s katerim ima podpisano pogodbo, po novem je to shell.
Urejal 4banger, 08.03.2018, 21:13.
Speed has never killed anyone. Suddenly becoming stationary, that's what gets you.
    • TIN je všeč
