Informacije o vpoklicih za vozila BMW
53 odgovorov v temi
damci
damci
    Navi guru
  • Sporočil: 10 600
Sem danes dobil mail od Makome z linkom, kjer se po VIN lahko preveri, ali obstaja za vozilo kaksen vpoklic ali tehnicna informacija. Mogoce pride komu prav (recimo za vpoklic menjave aribagov, ali pa AGR):
https://www.bmw-serv...icne-izboljsave
Urejal damci, 01.06.2021, 18:33.
TIN
TIN
  • Sporočil: 6 009
  • Lokacija: CELJE
  • Avtomobil: E30,Mpower,M140i
kako pa zveš za katero zadevo je akcija oz vpoklic? nisem našel,samo kodo tehnične akcije dobim.
  • Sporočil: 15 395
google it !
  • Sporočil: 26 201
Meni napiše vpoklic ... a sem ga imel že lani ... kode 0032200300 pa tudi gugl ne najde ...
Bmwe46mb
Bmwe46mb
  • Sporočil: 1 286
  • Avtomobil: Xc60
Hvala Lepa za info
Mi je tudi vrglo van to kodo.
damci
damci
    Navi guru
  • Sporočil: 10 600
Hvala Lepa za info
Ne vem kako googlas, prvi rezultat:
the affected area is a plug connection from the wiring harness to the fan regulator of the heating and air conditioning system. According to BMW’s answer, this could overheat due to fretting corrosion. This in turn may lead to short circuits, to a melting of the plug contact or, it goes on to say, “in rare cases” to a “thermal event”, as the “Focus” quotes. This fire hazard affects not only running vehicles, but also parked vehicles.
According to BMW, a 60-minute visit to the workshop is sufficient to rectify the problem. The global company has issued three campaign codes for the recall, these are “0061830500”, “0061660400” and “0061830400”. The authorized workshops check the plug connection and overhaul it. It may also be necessary to replace the fan regulator
Iztok, tega tudi jaz ne najdem. Poklici jih ali jim poslji mail.
Bmwe46mb
Bmwe46mb
  • Sporočil: 1 286
  • Avtomobil: Xc60
Danes klical na BMW Denzel Klagenfurt in naslednji teden bodo uredili.
Čudno je to da so rekli da avto pustim ob 09:00 pa ob 13:00 pridem iskat?!
  • Sporočil: 26 201
...  Iztok, tega tudi jaz ne najdem. Poklici jih ali jim poslji mail.
Je že mimo ... sem lani dobil vabilo po pošti in se jeseni naročil na Avtovalu kjer sem pred 21. leti tudi kupil E46 - v pol ure so zamenjali oba prednja AB.
Za F30 pa (še) ni bilo nobenega vpoklica ...
Morajo prej naročiti dele - pa še malo časovne rezerve upoštevajo, če ne bi šlo vse gladko ...
    • Bmwe46mb je všeč
Benady
Benady
  • Sporočil: 2 761
  • Avtomobil: F45 218d
Damci, hvala za uporaben link :ok
Po dveh mesecih od prejema sem opazil message na connected drivu :-D  kot kaže imam vpoklic za EGR, koda 0011870500 :)
Blue30
Blue30
  • Sporočil: 800
  • Lokacija: Marburg
  • Avtomobil: F45
Sp ti menjali EGR? Meni je po tel rekla, da preverijo in menjajo po potrebi. Pri Gadyju so rekli, da ponavadi menjajo, pri Selmar Celje pa ne vem, kaj bo.
Benady
Benady
  • Sporočil: 2 761
Ne niso ga menjali, so ga preverili in naj bi bil OK
mistral1
mistral1
  • Sporočil: 609
  • Lokacija: Savinjska
  • Avtomobil: Fxx
Hvala za link,
mogoče kdo ve kaj bi bilo Koda tehnične akcije STOP011056, avto je F20 LCI 116d. Iskal sem po Googlu vendar nisem našel nič uporabnega.
Lani sem sicer imel vpoklic za nekaj v povezavi za puščanjem hladilne tekočine.
M power
M power
    Kakegae no nai
  • Sporočil: 17 144
  • Lokacija: Caporetto
  • Avtomobil: 2020 G21 320d Xdrive
Danes sem dobil še poziv za menjavo zračne blazine...
1986 E30 325iX > 1993 E36 318i > 1991 E36 325i > 2001 E46 330Xi T > 1999 E46 316i > 2001 E46 330Xi > 2004 E46 330Xd T > 2016 F11 520d Xdrive > 2020 G21 320d Xdrive
fp4492
fp4492
  • Sporočil: 1 231
  • Avtomobil: 330d F31
Tudi jaz
rok46
rok46
  • Sporočil: 1 891
Kam ste to dobili?
podpis
DJ Falco
DJ Falco
  • Sporočil: 3 781
  • Lokacija: Ptuj
  • Avtomobil: ///M2 Competition
myBMW app.
    • fp4492 je všeč
snowlotus
snowlotus
  • Sporočil: 455
  • Lokacija: SLO
  • Avtomobil: A4 Avant 3.0 TDI
Spet Takatini airbagi. Se mi je kar zdelo, da bo samo vprašanje časa, kdaj bodo noter zajeti tudi novejši modeli. Me prav zanima, če bodo vpoklici tudi pri drugih znamkah (Seat, Škoda, Citroen, Land Rover, Jaguar…).
Tisti, ki imate BMWje, M volani imajo Takatin Airbag, pa tudi F45/46/48 in F15/16 imajo v vseh verzijah Takatine Airbage.
F01/07/10/11 in serija 6 je na varni strani, če ni M volana z okroglim airbagom. Ostali volani imajo AB od AutoLiv.
F20/30/31/34/36 velja isto, M volan z okroglim AB je Takata, ostali so TRW.
Če komu koristi ali pa ni dobil poziva.
Urejal snowlotus, 17.04.2023, 06:35.
    • Nixxon in fp4492 uporabnikom je všeč to sporočilo
Taucher
Taucher
    Licence for sale
  • Sporočil: 10 805
jaz sem imel na f31 tokrat drugi vpoklic, za airbag (volan), tako da po nekaj mesecih čakanja sem dobil klic da je prispel in evo so zamenjali...
prvi vpoklic je bila volanska letev, katero so ravno tako zamenjali... ostalih problemov z avtom nimam, redni servisi-olja filtri, gume, zavore,... obrnilo se bo 200 kkm večina po AC, tako da ketna še kar prva. Kdaj bom menjal preventivno ali redno ne vem, bom vztrajal do nekje 225-250 kkm, potem pa en velik generalni servis, pa šopaj dalje nabijat km... :ok
dnjehen
dnjehen
  • Sporočil: 5 969
https://www.thedrive...-can-catch-fire
N20
Per BMW’s safety recall report, the problem stems from blow-by-liquid from the positive crankcase ventilation system, which can drip liquid onto the plug connector that may not be properly sealed. According to BMW, over time, that fluid can leak into the plug and potentially short-circuit the wiring. “This could increase the risk of a thermal event and, in rare cases, a fire,” said BMW in the NHTSA report.
pajdo
pajdo
  • Sporočil: 16
  • Lokacija: mb
Tudi jaz sem dobil poziv in prijavljen pr Selmar Maribor bomo videli kak bo in sicer
Na vašem vozilu so 3 tehnične akcije, EGR hladilnik, programiranje kontrolnih enot ter pregled zaponk v prtljažnem prostoru.
Termin za TA  6.5.2025 ob 8:30 uri.
Ok bomo pocakali  :-D :-D
