INPA - težave, nasveti
267 odgovorov v temi
muflon
muflon
  • Sporočil: 935
  • Lokacija: okolica domžal
  • Avtomobil: 3x e34
Če komu kaj pomaga glede priklopov itd :ok2
http://forums.bimmer...d.php?t=1505990
Lp :mznakare
    • mateus je všeč
JohnyR
JohnyR
  • Sporočil: 722
  • Lokacija: KK
  • Avtomobil: BMW M5 (E39), 320i (E36)
A ima kdo kakšen pdf kje so razložene te napake oz te decimalne vrednosti??
Za napake, ki mi niso jasne jaz ponavadi vprašam strica Googla, al pa tuki gor vprašam.
A Supra will emerge and take the throne !!!
bojan.u
bojan.u
  • Sporočil: 2 842
  • Lokacija: Žalec
  • Avtomobil: BMW E60, 530d
:-D, mislim, da je forum namenjen pomoči in informacijam in ne preprosto "poguglaj" in izvedel boš...:-D
bmw
bmw
  • Sporočil: 5 598
  • Lokacija: LPG petrol station
  • Avtomobil: 2x 12l/100km
Narobe misliš
JohnyR
JohnyR
  • Sporočil: 722
  • Lokacija: KK
Vprašal si preveč splošno, zato si dobil tak odgovor.
Napiši tu gor kaj za eno napako ti javi, pa ti bomo mogoče lahko bolje pomagal.
bojan.u
bojan.u
  • Sporočil: 2 842
  • Lokacija: Žalec
Prosim če mi kdo "razvozla" ti dne napaki?
Hvala...
damci
damci
    Navi guru
  • Sporočil: 10 170
napaka 44 v motornem računalniku:
CODE 44
Trouble Code 44 indicates that the O2 sensor is showing a persistently high exhaust oxygen content (lean), despite the efforts of the ECM to increase injector on-time (thus increasing fuel delivered). Integrator and BLM numbers may indicate > 128 by a substantial margin.
The conditions for setting this code are:
* no Code 33 or Code 34 (MAF Error) present, and
* the O2 sensor voltage remains below 250 mVolts, and
* the ECM is in Closed Loop control, and
* the above conditions exist for more than 50 seconds.
Typical causes for this code include:
1) O2 sensor defective or lead shorted
2) Lean injectors (dirty or blocked)
3) Water in fuel
4) Exhaust leaks upstream of O2 sensor
5) Fuel pressure or volume too low
6) MAF sensor reading lower airflow than is actually present
7) Vacuum leaks
8) Incorrect or poorly calibrated PROM
bojan.u
bojan.u
  • Sporočil: 2 842
  • Lokacija: Žalec
Hvala za hiter odgovor....:)
Ali lahko prosim dodaš kakšen link ali nasvet kje najti razlago kod za serijo e60?
Kje bi po tvojem mnenju začel pri odpravi napake?
Hvalaaaa...
RS6
RS6
  • Sporočil: 7 041
  • Avtomobil: e24 635csi
Urejal RS6, 19.12.2010, 23:20.
bojan.u
bojan.u
  • Sporočil: 2 842
  • Lokacija: Žalec
Sem nekaj brskal pa sem za DDE 5.0 našel :
4477 - Intelligent Battery Sensor
no communication via BSD interface
JohnyR
JohnyR
  • Sporočil: 722
  • Lokacija: KK
Hvala...
Drugače, je to samo pregled vseh modulav na avtu.
Če boš šel v del programa za DME, boš dobil več podatkov o napaki.
Flyer29
Flyer29
  • Sporočil: 82
  • Lokacija: Murska Sobota
  • Avtomobil: BMW 530dA
Danes sem priklopil avto na INPO in mi je javil ti dve napaki, ki jih seveda ne vem razvzlat:
-A2 sbsr (spodaj napisano še 9913 60) in
-62 mostgw (spodaj napisano še e18f 20
Tale prva sbsr, je menda problem z mrežico na sovoznikovem sedeži (kolko sem uspel izvedet v googlu), za ta drugo pa res ne vem...
Mogoče lahko kdo to razvozla?
Aja pa še nekaj...v kateri menu v INPI moram it da mi pokaže pretok zraka na LMM senzorju...da preverim, če je kaj narobe z njim...
Hvala za odgovore...
JohnyR
JohnyR
  • Sporočil: 722
  • Lokacija: KK
Napiši kater avto in motor gledaš.
LMM podatek se vidi v delu za motor. Ponavadi z F5 gledaš podatke ki so povezani z delovanjem motorja.
Flyer29
Flyer29
  • Sporočil: 82
Gre se za 530dA E60, motor pa je M57N...
Aha...pol greš pod motor in F5...a se lahk pol pelješ z priključenim računalnikom...da vidiš delovanje LMM-ja?
JohnyR
JohnyR
  • Sporočil: 722
  • Lokacija: KK
Lahko se pelješ in gledaš. Čeprav je bolje da pelje kdo drug, ko ti gledaš podatke, da ne bo bum.
Ne vem če boš kar tako videl ali LMM dela pravilno ali ne. Dobro bi bilo imeti neko referenčno vrednost. Recimo, da se z drugim (enakim) avtom voziš konstanto po določeni cesti (ravni odsek AC je primeren), nato pa še s svojim, da lahko primerjaš podatek.
Tiste napake, ki si jih napisal prej, pa je potrebno prebrati vsako v svojem modulu, ker potem dobiš celotno informacijo o napaki.
Flyer29
Flyer29
  • Sporočil: 82
Sem danes priklopil INPO na avto in prišel do menuja, kjer lahko spremljaš pretok zraka skozi LMM, vendar se mi ta tester malo čudno obnaša, ker včasih so bile vrednosti ok in so se spreminjale glede na to kolko sem dodal plina, pol pa so kar naenkrat izginile. Hkrati z tem so izginile tudi pravlne vrednosti obratov, napetosti baterije...
Kaj bi lahko botrovalo tem prekinitvam???
Prilagam tudi print screen iz INPE in sicer v trenutku ko so vrednosti izginile...
  • Sporočil: 20 827
Tele "kosmate" INPE imajo pač to grdo navado, da gredo včasih malo v cvet ... :ok2
Flyer29
Flyer29
  • Sporočil: 82
Se pravi da je za to kriv program? To se mi dogaja vse na par sekund...da prekinja...
  • Sporočil: 20 827
Prekinja ravno ne, zna pa kakšen parameter v on-line kazat malo drugače kot tovarniški tester.
Za prekinjanje pa je ponavadi kriv sam tester - hardware, ker ne ločuje pravilno nivojev signalov (logična 1 in 0). Ko sem pred leti sam razvijal tester sem imel ravno s tem največ dela.
damci
damci
    Navi guru
  • Sporočil: 10 170
tako je ponavadi so krivi low cost testerji
